What top speed should the 700 get?
Old Aug 16, 2004 | 12:21 AM
travelor's Avatar
Default What top speed should the 700 get?
I top out at 59 with stock tires and 57 with mud lights by the speedometer, which is also probably high. This is with the plain white spring. Did the same with blue spring. Best I have ever seen was 62,before the key change. It does seem to spin pretty good. If I wheelie, I let up slightly and can't get it up again so my wheelies or only a couple feet.
Old Aug 16, 2004 | 12:36 AM
kawasaskirules's Avatar
you should be way higher!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 16, 2004 | 01:07 AM
NovaKaw650's Avatar
I suspect that something is amiss with your tuning. How fast did it go when it was dead stock? You should get in the 65mph range on a long stretch of road.
Old Aug 16, 2004 | 01:13 AM
travelor's Avatar
I did not really try it dead stock. Maybe with my 290 lbs. slows it down. I am jetted pretty high but seemed to gain 2 mph after the jet kit.
Old Aug 16, 2004 | 07:30 AM
Nutsy's Avatar
I am 220 lbs. and get 67 mph
Old Aug 16, 2004 | 08:20 AM
SHOTGUN's Avatar
Is your key in right?
Old Aug 16, 2004 | 06:40 PM
STAKK's Avatar
I ran 67 mph also stock....with the Dyna CDI, EPI black secondary and Polaris blue/green primary with stock jetting.....71 mph (190 lbs friend)......I added the napa snorkel and 142/145 mains 72 mph...level ground with my 190 lbs friend having the guts to hold it to top speed.........
Old Aug 17, 2004 | 12:24 AM
travelor's Avatar
I think I should quite worrying so much and just have fun, Just that I want to make sure it is as good as it can be with what I have. I only get 58 now with the original tires. Am going to take it in to the shop one last time and then just be happy.
Old Aug 17, 2004 | 02:21 AM
minimus's Avatar
With dg3 and key twin air filter, after mods I can hit 65-66 on a long stretch.
I wonder what tire sizes do to the speedo. I also am at 4,500 feet, at sea level that 66 may be 68-69.
You out weigh me by about 40 lbs and that could be 3-4 mph difference. (guess)
Have someone smaller ride the machine? If they get the same result than it could be a machine problem.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
