I having problems with my ATV
Old Aug 16, 2004 | 09:37 AM
dadsworry's Avatar
Default I having problems with my ATV
My proplem is that my lakota keeps bogging/stalling out any time I give it any gas whatsoever. does anyone know what this may be?
Old Aug 16, 2004 | 10:17 AM
WVatvRider's Avatar
Check air filter first, if clean and good, check spark plug. If you havent put in a new spark plug in awhile get one and try it.. if that isnt it, drain the gas, you may have gotten a bad batch.
Also check your choke, make sure it isnt sticking.
Air Gas or Spark....got to be one of those.
If none of the above work you will need to test to see if you are getting good spark..
Remove spark plug, attach to sparkplug wire, ground on your cylinder head and turn over the motor, if you see good spark must be gas.
If you dont see good spark, could be ignition probs.
Good Luck
Old Aug 16, 2004 | 11:51 AM
hondaguy2's Avatar
the float may be sticking cause my friend has the same problem you do
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
