belt problems
Old Aug 28, 2004 | 10:01 PM
cantspel's Avatar
Default belt problems
I've got a p360. I've been fighting belt squeal since new. I've corrected belt deflection twice. I recently bought a Dayco HP2019 belt for it. I went to install the belt today and found it to be too big. Even after I removed my last 6mm shim, I still have about 1.3" of deflection with the Dayco. When I put the old used up Kawi belt on, I have about .6". This makes the stocker too tight, and drags the trans when in gear, but the Dayco is too loose. Anyone else run into this? Did I get a bad belt? The Dayco looks light years ahead of the junk stocker, I wish I could get the deflection right so I could use it. Has anyone machined a couple thousands off the sheaves in order to correct a similar problem? Thanks
Old Aug 28, 2004 | 10:42 PM
redbruteforce's Avatar
The first thing you should do is find out how much deflection there should be and then go from there[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 28, 2004 | 10:45 PM
cantspel's Avatar
.69"-1.03"
Old Aug 29, 2004 | 11:43 AM
Jeffro31's Avatar
I would call Dayco and see what they say about it ,that definitely does sound too loose.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
trouttracker
Jul 20, 2015 11:54 AM
