I really need help on Belt Flashing Light P-650
I went through the complete light reset procedure--disconnecting the connectors, reversing two of them, turning key on/off etc. I have done this a few times before and it has always worked before--so I really understand how to do it.
This time it didn't work after several tries. So I removed the belt cover to check the switch, sure enough it was "ON" so that was OK. Then I checked the resistance of the switch, it is "open" (infinite ohms) when it's "ON" and also "open" when it's "OFF". I would expect it to be closed (0-ohms) in one position and open (infinite ohms) in the other position. Since the belt light would not reset and the resistance was infinite (open) I figured that this switch was bad and was causing the problem. So I just shorted the two wires together so it would appear that the switch was ON (closed) and operating normally. I still can't get the belt light to reset and stop flashing.
Now I am really lost for any more ideas--Help please, 'cause I'm leaving in a couple of days for the ATV ralley in Richfield Utah.
so the light is intermitantly coming on? if so its either your battery terminals being loose or somewhere in the ignition is a fault...aside from that the only thing I can say is the connector from the kebc doesnt get hooked up till after you turn the ignition back off and have the other two "crossed" connectors back to normal..that last step is very important...youve said youve done it before so thats all I can offer..soz
I understand that the later model P-650 do not reduce power (sputtering, coughing, etc) when the belt light flashes. Mine is an early model P-650, so it sputters. Is there anyway to modify a wire to the Ignition module to stop this power reduction on the early-model P-650? It's a real pain when you're out in the boonies to have to deal with this problem. Mine is more serious now, because I can't get the %$#*&@#! light to reset, the ATV only has 60 hours and the belt is in great shape and the belt switch is ON (in the back position)and I've gone through Nyroc's reset procedure several times. ARGH!!
DickLakeTahoe, there is a way to stop the limp mode, Its called Dyna CDI it overides that feature along with the reverse limiter. Not to mention the performance gains you will see. (especially if you dont have any other module) ie: holeshot, naber, ect. Then its a night and day difference.
Thanks for all your help and suggestions. I finally figured out that my Belt switch had failed, and indicated that it was "off". So I corrected that by shorting the two wires from the sensor together. Then my battery was really low, so even though I went through the whole re-set manuver, the belt light still kept flashing. A new battery fixed that problem and now everything works great. So my wife and I are off to Richfield Utah, on Friday, for the ATV rally there with the ATVs working great. Thanks againg for the help. BTW, I contacted Nyroc directly and he helped me with additional suggestions--so a big THANK YOU to Nyroc for his help.
speedbuff
13
11-11-2020 10:16 AM
Steeldon
09-09-2015 09:38 AM
