Stop to put in 4wd or not?
Old Oct 9, 2004 | 07:54 PM
Customfabandweld's Avatar
Default Stop to put in 4wd or not?
Moving under 15 MPH with all 4 wheels spinning the same speed is the ideal way. However, I have been stuck before I switched to 4WD so I just put in 4WD(not moving because I'm stuck!), then I put it in low gear and try to spin the real wheels very slowly with the throttle, forward and reverse. You are trying to get the gear dogs to line up, so they will mesh. If you get the rear wheels spinning too fast you are likely to hear that aweful gear clashing noise. I have had good success with this method, however, as already stated, the best way is doing it before you get stuck![img]i/expressions/face-icon-small-shocked.gif[/img]
Old Oct 9, 2004 | 09:08 PM
maddog56's Avatar
I believe kawasaki, and i thought nyroc and many other knowledgeable members of this site recommended that 4wd/2wd shifting Never be done at a complete stop, but rather, while at speeds under 5mph.
Old Oct 9, 2004 | 10:23 PM
pads's Avatar
Thanks for all the replies. This site is so much better than the manual.
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
tysonbully
Sep 28, 2015 02:30 AM
Jackg17
Sep 26, 2015 09:30 PM
