360 prairie oil level
Please excuse my igorance but can someone advise me how to check my oil level. When using the screw in dipstick do I screw it all the way back in and then remove it to check the oil level, or do I just stick it in and out .
Welcome to the forum Checkers--always great to have P360 members---On your dipstick, you will see the checkered part at the bottom of the stick---This means that oil level anywhere in this checkered part is acceptable--you do not have to be up to the top everytime--some bigger Kaws were getting oil in the airbox from running the level to high---With dipstick screwed all the way in, level should be near the top of the checkered area, NEVER OVER IT! Checking oil without screwing dipstick in should be somewhere below top of checkered area. Remember, your dipstick is a guide and does not have to be exact--Too full is no good, either is too low--There is leeway so use common sense.
