Primary spring article
Old Mar 11, 2005 | 12:42 PM
KISSSOFDEATH's Avatar
Default Primary spring article
Thanks rivermud, that is correct about the hp.
$300 seems about right for the cams. Was that delivered?
Thanks for the answer, thats the kind of answer I can relate to. I want the cams bad but want the head work done too. I may fork over some money and have an expert like Ray at Fundy powersports do it. Decisions Decisions.
Old Mar 11, 2005 | 01:35 PM
tuffEnuf's Avatar
KOD I hear Ya on Decisions, Decisions. Port and Polish would be the Icing on my Prairie also.
Prairie Wrench just sent his 700 heads to Ray be ported & Polished. Maybe he can shed some light on cost & how it performed. He also said that shipping was just $50.
TuffEnuff[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 11, 2005 | 03:15 PM
rivermud's Avatar
The i picked up the cams so no delivery. They come in a pretty small box so shipping shouldnt be much from MO to NC. I had every intention to let Rick Ritter do my heads since he is somewhat local (avoid shipping), very nice guy, and has a great reputation. The price was fine but he was so busy it was about a 2 week turn around and I had to get the quad back together for a planned ride. The place I went had them ready for pick up the next afternoon. couple days now. It just says:
The brute belt sounds like it will be worth trying. Whats up with nyrocs site? I havent been able to get on it for a couple days now. It just says: The Web server connection was closed.
Old Mar 11, 2005 | 03:25 PM
rivermud's Avatar
nevermind about nyrocs site, I just tried again and it worked fine.
Old Mar 12, 2005 | 01:41 AM
  #15
kawiyowee's Avatar
KOD: Ordered 4 of those altitude shims and we have about 5 springs to try, so will try some stuff and post it for you and the forum. It's my understanding that it doesn't matter what altitude the springs are tested at as long as the bike is running well re jetting and clutch weights.
Old Mar 14, 2005 | 12:17 AM
  #16
rutwad's Avatar
So would heavier weights cause the "shift point" to happen at a lower rpm? And the opposite true for lighter weights?
If so and I am 2 mph away from my rev limiter in high, then it seems like heavier weights would push the belt to the outer edge of the primary sheaves sooner (lower rpm's).
I have not seem a power of torque curve of the Prairie, and mine would be different since it has been modded, but maximum power is usually available before reaching maximum rpm's. So assuming that since I am only 2 mph away from my rev limiter, it seems safe to assume that I am already on the down side of the power curve.
That being said, could I use heavier weights to push the belt to the outer edge sooner, thus reducing my rpm's for the same speed as with the lighter weights. Lower rpm's should place me back closer to my peak power range, possibly allowing for more top speed. Or at least the same top speed at lower rpm's?
Hope this makes since.
What do you guys think?????????
Old Mar 14, 2005 | 12:25 AM
  #17
rivermud's Avatar
If you havent done it already, the top end clutch mod will allow higher top speed with less rpms. Usually at least 3-5 mph. Not bad for a free mod!!
Old Mar 15, 2005 | 12:45 PM
  #18
rutwad's Avatar
If I did the top end clutch mod, I guess it would have to be for bragging rights. Not often do I need to trail ride at 70+mph!
If changing to heavier weights would push the belt out on the primary sheaves sooner, wouldn't that be like a slightly higher gear ratio? Same speed at lower rpm's?
Old Mar 15, 2005 | 02:29 PM
  #19
Brute4ME's Avatar
Don't shoot me for asking, still getting used to the bike. Trying to apply my snowmobiling clutch knowhow to this, they seem to parallel each other. What is the top end clutch mod??
ghost civic
Jan 15, 2020 07:43 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
