Overflow Tube
Old Mar 23, 2005 | 12:43 PM
Plainsman's Avatar
Default Overflow Tube
Im not sure. Maybe check the kawasaki site and look at the diagrams? You shouldnt keep filling that tube with the plug with gas. Notice gas in the airbox?
Old Mar 23, 2005 | 12:58 PM
fflynn's Avatar
I have seen gas in airbox... that is where it overflows to... which is why I am trying to find if there is an overflow tube so I can see why it is not coming out of it as opposed to the airbox?
Old Mar 23, 2005 | 01:26 PM
Plainsman's Avatar
I belive so, trace the hose up with your hand.
Old Mar 23, 2005 | 01:41 PM
fflynn's Avatar
Well, you may have mis-understood what I said.
When gas overflows, it comes out of the back of the carb and soaks the air filter. I would not think that is by design. If there was an overflow tube, I would not think it would route gas into the air filter
Old Mar 24, 2005 | 12:07 PM
  #15
tuffEnuf's Avatar
FFlyinn
Would help if you stated what type quad you have. On the prairie it the forward RH corner of your airbox. Other drain hoses are routed down and around CVT case, just retrace the one thats dripping.
Does shutting off your petcock when you are done riding Not help? May try checking, Either your floats are not working/stuck/ got matter caught in them or your choke plunger springs are sticking/weak/need lube.
Just shutting off the fuel when you are done riding or transporting your Quad works well to prevent overflowing on the Prairies.
Happy trails,
TuffEnuff[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 24, 2005 | 01:21 PM
  #16
fflynn's Avatar
Thanks for the response... it is a 1996 Bayou 300 4x4.
I have now got into the habit of shutting the fuel off, but I am still concerned that while I am driving excess gas may be leaking out.
Old Mar 25, 2005 | 12:32 AM
  #17
tuffEnuf's Avatar
If it was leaking while your driving you should smell it. Inspect your arbox after it has set all night with the fuel shut off. If its dry, start up and take it for a few high speed runs, Shutdown & recheck.[img]i/expressions/face-icon-small-cool.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
CosmoM
Sep 21, 2015 04:57 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
