Lakota Sport head light
Old May 8, 2005 | 03:42 PM
katstoy's Avatar
Default Lakota Sport head light
Has anyone added additional headlights or swapped out the stock? I hate the stock headlight as it's not bright enough and I'm not able to adjust it to where I need it to go! Yes, I tried the screws on the sides and moved it up and down, but I'm still not happy. So, has anyone added more lights? (Hmmmm, maybe it's not the lights, but the ole' eyes are going? Nah, it's the lights!)
Old May 8, 2005 | 04:31 PM
holeshotz8436's Avatar
ya i did it to mine but the lights came with plastic brackets so they broke..............anyway this is what you could do. go to walmart and look for a smaller set of headlights that has a bolt comming out of the bottom and thats how it mounts then mount em where the bolts for your front plastics go and just remove the screw and stick the bolt from the headlights thru there and tighten it down, when you wire it makeshure you use the extra fuse circut thing that will come with the lights because if they ever blow a fuse you dont want your quad to die out on you and on my lakota anyway there were 2 wires up by my cdi box andi just wired the lights to those wires and put a toggle switch on my left fender by the mudflap and they worked perfect till i filpped the quad and broke one.
Old May 8, 2005 | 11:00 PM
Shortcut's Avatar
I replaced the hood with a maier and bought a set of piaa driving lights. Mounted one on the bars and one on the hood, worked great !
Old May 11, 2005 | 01:06 PM
katstoy's Avatar
Thanks, I will definitely try something.
Holeshotz - did you still run your stock light too? Did you have to change out any other parts, ie. stator, fuse box, etc, or was just putting the additional fuse in ok? (PS - ex patriot yankee here, born and raised in Stamford and did 4 years in Storrs - go Huskies!)
Shortcut - saw a pair of the piaa lights on a Jeep Wringler this morning - sweet! They must look great on the quad.
We're hititng the sand dunes at glamis this weekend, so I may buy some lights today or tomorrow and have one of the more smarter gerar heads do some wiring for me. Thanks again.
Old May 11, 2005 | 10:39 PM
ya i ran all three at the same time and never had any battery problems at all........i just used all the wireing that came with the lites like the switch and extra fuse and i hooked them up and they worked great but make shure you get ones with metal brackets because someone flipped my quad on its side and just the impact snapped the bracket
Old May 12, 2005 | 12:55 AM
NEWDUCK's Avatar
Thanks for the idea holeshot i had just bought some wal mart lights and i cant decide where to mount them but now i know. Did you buy the fog lights? thats the ones i got that are in the shape of a an oval.
Old May 12, 2005 | 08:13 AM
the ones i had they dont make any more but i saw those fog light ones and i think those are the ones im going to get this time around, they seem like theye would hold up better then mine did my other ones were xenon and immitain high intensity discharge, the only problem is that when i had everything on and i rode thru some mud it screwed up the toggle switch and i had to change those out a few times so make shure you put the toggle switch somewhere up by the hadlebars or somthing
Old May 12, 2005 | 06:38 PM
NEWDUCK's Avatar
got any pics with yours mounted?
Old May 12, 2005 | 06:46 PM
nope, the bracket broke before i got my digital cam
bzdok1234
30
Feb 23, 2016 01:55 PM
ScopeZ_
Jul 28, 2015 01:44 AM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
John Boy
Jul 13, 2015 11:16 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
