coolant leak????
Bonjour,
I have a leak on my prairie, the little plastic bottle (breather under the pump) is always full of coolant , some people told me about a 'seal-leake' from the pump, anybody see that before? all your help
wil be appreciate.
thank you,
Sylvain.
wil be appreciate.
thank you,
Sylvain.
Coolant can leak out of the radiator cap and run down the lines, making it kind of hard to notice. Or the resevoir plastic cap can crack if its overtightened. Those are the only weak spots ive run into. Might be a leaking line. If your unsure where to look, some coolant dye and a black light will be your best friend.
exmotocrosser
Sep 13, 2019 06:12 AM
jrooker6
Apr 23, 2016 07:36 PM
