Lakota vs Warrior
Old Jul 11, 2005 | 01:27 PM
  #21
mojavemadman12's Avatar
Default Lakota vs Warrior
Originally posted by: holeshotz8436
AC i did some checking and you are right about the weight, i thought that the warrior weighed more because of some very old posts on the fourms about a warrior vs lakota that a read a long while back and some specs for the lakota state that it weighs only 429 and it seems there are alot of descrepincies about the lakotas weight and weight can be shed from the lakota very easily because their are alot of stuped things that weigh alot that can be removed/replaced like newduck said but this might be the same with the warrior too......both atv's arnt exactly light either compared to many other sport quads so i apoligize for bashing your statement but if both atvs were stroked and bored out the maximum reliable size would be around 400ccs for both posibally 420cc with the warrior so if they were both completely modded and stroked and bored out mostlikely both atvswould be just about even and posibally the warrior would pull away a bit in 6th like newduck said and is the warriors ground clearance measured under the skid like the lakotas? I would still preder the lakota when mudding because of the bigger tires, the decent ammount of bottom end power because its a utility based engine and especially the semi auto tranny becasue it wont stall and the manuel tranny can cause quite a bit of problems when it stalls on a real steap hill so especially for someone whoes not great with a clutch the lakota migt be a better choice for that kinda thing. basically each quad has its ups and downs and i dont hate warriros, infact i almost sold my lakota and bought one when i started doing alot of track riding and racing thru flat trails because i like the 6 speed and cluth but i decided to keep the lakota and mod it because i like to see the reaction on peoples faces when i beat them because most people underestiamte it because of its smaller size. but as far as mojavemadman you still have said nothing tyo back yourself up and your postes still make no sense and assuming you have a stock mojave i highly doubt you can beat my lakota and im shure other not as cocky mojave owners will agree. Anyways.....walker did you make a choice yet?
stock 4 stock i think my mojave will ruin you but if i had all the same mods as you i would ruin you. i can loose my friends in 3,4 gear in a drag and he has a "01" wolverine with a cobra exuast system and jets.so yours is a 300 lokota and my friends is a 350cc. and mine 3,4 gear i can loose him . [img]i/expressions/face-icon-small-smile.gif[/img] Have a nice day.............
Old Jul 11, 2005 | 03:25 PM
  #22
NEWDUCK's Avatar
The only problem is there is no such thing as a 350 lakota or are you talking about the wolverine?. If you would really think about it you should be able to beat the wolverine because first its shaft drive so you loose power there and second it is always in 4wheel drive so you also loose power there. So far to my knowledge I have the biggest bore lakota but not for long once greg gets his stroker crank done [img]i/expressions/face-icon-small-smile.gif[/img] . Right now i beat the warriors but once i can get gregs true high comp piston and not the crap one i got from fst i should be able to hang with a stock 400ex.
Old Jul 11, 2005 | 03:31 PM
  #23
Vunit's Avatar
with a cobra exhaust you dont get any performance what so ever and all the jets are doing is giving him better throtle response...so he is gaining nothing... its always 4wd and its shaft drive as well like NEWDUCK said so you should have no problem beating him...stock for stock the mojave is faster than the lakota yes...but when both the lakota's and mojave have the same mods on...and you takes some of the weight off the lakota than they will be about even...with just a pipe,jets,bigger carb and a bigger front sprocket it wakes the lakota up like you wont believe...and lakota is spelled LAKOTA not lokota!!!
Old Jul 11, 2005 | 03:38 PM
  #24
yeah right my a$$ a lakota hang with a 400ex yeah wat r u smokin.........
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 11, 2005 | 07:02 PM
  #25
BloodyRomance's Avatar
first off...why don't you just get the better bike to start with if you want to hang with a 400ex? because by the time you get all the mods on it you'll spend more than if you just bought the better, faster bike.
second...why would you want to take a lakota and put all the mods on it anyways? thats like taking a volkswagon and spending a crap load of money so you can hang with a mustang!.....moral of the story: just get the better bike!
Old Jul 11, 2005 | 10:05 PM
  #26
holeshotz8436's Avatar
mojavemadman stop making your self look like an idiot and you shouldnt be bragging about being able to beat a 350cc 4x4 utility quad, you should be able too.....if you beat a p650 then thats somthing you brag about and i bet that wolvy has pulled you outa some muddy situations too where you would have been screwd it the wolvy wernt there, thats what smaller utility atv's are ment for not 4 dragging unless its modded and all a cobra pipe does is make added noise and nothing else......your buddies money could have been better spent burning it.....corbras are just good stock replacements thats all and i raced a piped mojave when i only had a pipe and jetts too and we were even it just depended on who got the better start
Old Jul 12, 2005 | 12:09 AM
  #27
ACFreerider's Avatar
I agree with this. With all the money sank into your lakotas you could have had much faster and better handling stock quads for same or less money. Thats why I didnt put much into my warrior & prob. not the quadracer either unless its reliable then I might make it a go fast quad.
Old Jul 12, 2005 | 01:25 AM
  #28
NEWDUCK's Avatar
Here is my total for my build
1200 for the lakota
400 for all the parts and free labor
about 280 for my pipe
that adds up to 1880. I dont know about you but ive never seen a 400ex that low in price.
Old Jul 12, 2005 | 02:27 AM
  #29
1200 for the lakota
free labor?! what kind of business you runnin out there?
Old Jul 12, 2005 | 12:59 PM
  #30
How is your lakota a 345 and you only put $400 into the engine? carb is like around 2 and Im sure you would need a bore kit to get that. Did you bore it out .55 and think that adds 55cc?
