1st Servive due
Old Jul 27, 2005 | 04:30 PM
curdawg's Avatar
Default !st Servive due
Will they do anymore than change oil, change filters, cleanit up and charge me an arm and a leg or do they reaaly do things Im not equipped to do?
Old Jul 27, 2005 | 05:55 PM
bailey1dog's Avatar
Default 1st Servive due
they should change the fluids in the diff's also, the only thing you really need them to do that you may not be able to is adjust the belt and add clutch shims if needed because the belts stretch the first rides.
if youre dealers anything like mine they will charge you arm and a leg, my local dealer sucks, hope yours is better and you wont have to doubt them.
Old Jul 27, 2005 | 10:46 PM
OffRder15's Avatar
My dealer supposedly changed all my fluids, adjusted my belt tension and checked my valves. And yes, it wasn't cheap but I had no choice b/c I didn't have the time.
Old Jul 28, 2005 | 12:16 PM
curdawg's Avatar
Thats kinda what I figured. My check belt lite on my 2004 Prarie 360 was staying on and I tried what was listed in the forum for a fix and it worked great. Just one word of wisdom. Try to do this without taking that tank cover off. Its a "female dawg" to get back on and the bolts are realllllll soft. I sheered one with just a little pressure.
MotoVintage
Kawasaki Side by Sides
Nov 16, 2008 02:24 AM
Perky
Aug 1, 2005 03:56 PM
zman420
Apr 21, 2004 05:20 AM
markvette
Sep 3, 2001 01:20 AM
