idel problem
Old Jul 31, 2005 | 03:01 AM
yamaharaptor350's Avatar
Default idel problem
My little brothers ffx80 doesnt want to idel... i thought it was the air filter was dirty so i cleaned it but it still dos it. It was not driven for like 2 weeks could the gas just be bad or what??? what do you guys think?? thanx and how long can gas sick before it goes bad im leavin my rappy sitin for 2 weeks startin monday, will the gas be bad by the time im back?? thanx again
Old Jul 31, 2005 | 01:22 PM
Chris142's Avatar
Gas can sit for several months.
hondabuster's Avatar
It varies by the additives that are in the gas. But roughly 3 months, is how long gas stays good with out any thing added to it, like seafoam or stabil. And the additives need to be added to fresh gas...once the gas has gone bad, those products wont make it fresh, they just protect the gas from evaporation of the most volitile compounds. Once they are gone, the gas is bad.
Will it run with the choke on, at idle? Is the idle speed too low?
If it was fine, the last time he rode, but now it wont idle...the pilot jet (slow jet or idle jet) is plugged. The float bowl needs to come off, and then clean out that small hole in the center of the pilot jet.
Old Jul 31, 2005 | 01:54 PM
thanx honda buster and i took his air filter out and it was the worst i had ever seeen... We were doin wheelies in 4 foot grass and the grass and pollen stuff got right into the intake and the filter was covered with the stuff but its clean now... how do you bump up the idel speed on these machines?? thanx
Old Jul 31, 2005 | 05:10 PM
Good question, too bad i dont have one of these to look at. The kawi parts finder isnt working right now, but i think the suzi 80 is the same motor and carb,
go here
Number 23 is the idle adjustment, its hard to spot, its next to the m of microfish. It rides in a tapered slot of the slide, as you screw it in, it moves the slide up.
Most likely, if it ran good the last time he shut it off, this wont be the fix. Its very common on the very small carbs, for the pilot jet to plug up. The hole in the center of the jet, is barely bigger than a spec of dirt, and it plugs up real easily.
Old Aug 1, 2005 | 01:59 AM
thanx agaian guys and whats the easiest way to clean it?? would carb cleaner get it or will i have to pull it out and shoot the dirt out with an air compressor??
Old Aug 1, 2005 | 02:20 AM
If its really stuck, you might need to push the obsturuction out with a small wire, but it wont hurt to use carb cleaner and compressed air. You can start by looking thru the jet, like looking down a straw. You should see light coming thru, keep cleaning til you can see the light.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
