Mojave seat
Old Oct 18, 2000 | 09:18 PM
hondabigred's Avatar
I was wondering if anyone new any tricks on how to get the Mojave seat off easily.
Old Oct 19, 2000 | 02:50 PM
mojaveaddict's Avatar
I am guessing that you are talking about removing the seat and rear fender assy and not just the seat. If so remove the two bolts that hold the fender brace on and remove the seat assy. Take the bolts to a hardware or tractor supply house and buy two of the clevis pins that have the half circle retaining clip instead of holes for a hair pin clip.(not sure what the proper name is) Make sure they are the same diameter as the bolts and long enough to reach through the frame and seat brace and still have room for the clip to latch. Put these in place of the bols and you can quickly and easily take your seat assy off without any tools. I run a clamp on K&N and so I have to remove the seat often to service the filter. With the pins it takes about 20 seconds to get off.
Old Oct 19, 2000 | 11:30 PM
Jeffksf's Avatar
Mojaveaddict has a good idea but on my Mojave I also had to enlarge the holes in the fender bracket directly under the seat. I made them larger then the nuts therefore those nuts still hold the seat to the fenders but not to the bracket. I only did this to 2 of the 4 screws and I just left the nuts off of the other 2 screws. It sounds confusing but look under the fender directly in the middle of the bike and you should see the 4 screws and nuts. I assume all year Mojaves are like this.
93 modified mojave
Old Oct 20, 2000 | 10:55 AM
98Lakota's Avatar
I took two 1/4" eye-bolts that were about 6" long and cut them to length. Drilled holes in them and put retaining pins in. Works like a charm.
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
