whats the hole below the thermostat on the Mojave for?
Old Sep 14, 2005 | 08:53 PM
haywoodjalikme's Avatar
Default whats the hole below the thermostat on the Mojave for?
Its the 1/8" diameter hole below the thermostat housing....I put a new head on the MO last weekend and the hole appears to be damp and it looks like antifreeze is seeping out of the hole.
Its a very small amount and I only have about 15 minutes of run time on it. I looked in my service manual and didn't see any info on where the passage goes.
Thanks guys
Jeff
Old Sep 15, 2005 | 04:46 PM
RotorTrash's Avatar
if its a clear or green color its antifreeze if its a brownish color its where you drain the oil
Old Sep 15, 2005 | 06:40 PM
rolsmojave3's Avatar
it's a weep hole for water that goes down by the spark plug...i noticed that when i pressure washed it and water came back at me from the hole when i sprayed the spark plug
Old Sep 15, 2005 | 08:16 PM
rolsmojave
Thanks for the info...I feel like such a pin head since I have 2 other heads sitting here and could have just followed the hole to see where it went.
The sight of antifreeze scared me alittle but now that I think of it, I had to take out a thermostat bolt to put the clutch cable 'tin holder' back on and I had already filled the radiator so some did seep out and what I didn't get wiped off must have just gathered around that weep hole.
Thanks for putting my mind at ease(just can't believe I didn't look at my other heads and had to post such a dumb question..lol)
Jeff
franklyme
Oct 21, 2016 07:18 PM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
toonces
Sep 5, 2015 01:14 PM
