KFX700 rear shock too damn stiff! How do I fix it?
Don't try and take a reading. It does not have air in the shock, it is filled with nitrigen (wrong spelling). When you try to take a reading it will let just a little bit out and it will then have to be refilled to the correct pressure to work correct. Not sure what the correct pressure is, but it is somewere between 150-250 psi. Work with the compression and rebound setting to change the shock. Might even try the setting the sag.
OutRacing
Technical and How-To Articles
09-03-2015 07:49 AM
