2003 360 4x4
Old Oct 12, 2005 | 07:37 PM
hunter300's Avatar
Default 2003 360 4x4
I have a 03 360 4x4
the 4x4 light keeps flashing and the 4x4 is not working have done the plug switching to reset still flashing
if any one have any thing to try let me know
Old Nov 17, 2005 | 03:46 PM
dusty12's Avatar
This happened to me yesterday while riding at 30mph. It reset when I restarted. I would like to know the cause / solution
Old Nov 18, 2005 | 09:01 AM
alwaysride's Avatar
Are you positive that the 4X4 is not working. Just because the light is flashing doesnt mean that the 4x4 is broken. try putting it in 4x4 and feel for it when riding. If it works you know it is just your engine brake actuator or somthing. My light flashes but the 4x4 works so instead of wasting my money on a new actuater i just taped off the 4x4 light and dont even knowtice it. My e/b actuater works some but not all the time but if you give it a slight amount of gas on the hills you get the engine breaking.
Old Nov 18, 2005 | 11:16 AM
dusty12's Avatar
This happened twice. When I tried to engage 4x4 with the light blinking it wouldn't engage. I did engage after i restarted the bike. a KVF 360 4x4
Old Dec 1, 2005 | 09:27 AM
doyle22465's Avatar
would someone tell me what makes the motor brake down when you give it the thottle
Old Dec 4, 2005 | 05:34 PM
airshot's Avatar
When a slight bump up in throttle is applied it causes the centrifical clutch to engage thereby connecting the engine to the drive train. These newer machines have electronic gizmo's that are supposed to do that for you, but from what I have been seeing they appear to be more trouble than they are worth. My 2000 praire 300 does not have these electric gizmos (thank God) however when going down steep inclines I just nudge the throttle up slightly to engage the clutch and the engine compression takes over. When we were down in Hatfield/McCoy I was able to keep my downhill speed under 7 mph on the steepest downhill without brakes or only slight braking. The big plus for me is no electronic gizmo's going haywire. With all that I have read I have talked myself out of a newer machine, as I have had NO problems with my older praire.
KenR
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
