Warn Winch mount on BF750
Old Oct 15, 2005 | 03:25 PM
BruteForceNewYork's Avatar
Default Warn Winch mount on BF750
Ok I need some help. I recieved by Warn 2.5Ci and mount plate, but the hardware on the mount plate (the U bolts) are not big enough to go arond the front tubes. Has anyone else experienced this? The box for the mount plate verifies it is the right mounting plate from Warn.
Could use some help as everything is all out in the driveway at the moment.
Old Oct 15, 2005 | 10:37 PM
archangel's Avatar
The U-bolts that come with the mounting plate are two different sizes...small ones for the back and larger ones for the front. Maybe you
mixed them up?
Old Oct 15, 2005 | 11:26 PM
Well while the possibility exists that I would be dumb enough to do that, i promise I have checked and I am using the larger of the two sets of U-bolts, the set for the back of the plate seem fine.
Old Oct 15, 2005 | 11:34 PM
archangel's Avatar
Do the holes line up on the mounting plate? If so, just purchase two bigger u-bolts. Maybe the good folks at Warn just put in the wrong size U-bolts??
If the holes on the mounting plate don't match up to the recommended mounting location on the tubes...again, maybe they made a mistake in packaging.
Let me know how it goes.
Old Oct 16, 2005 | 12:35 PM
No the plate seems to be ok, the bolts are definately not the right size. Thats not a bad idea, I can check Home Despot for a larger bolt.
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
