Mojave problem
Old Oct 29, 2000 | 08:48 PM
hondabigred's Avatar
I took my mojave out it ran perfectly until I went around a turn and it just started missing for about a minute and then it just died on me and wouldnt start at all. Pulled it home and the next day it started right up and it did the same thing.Now it wolt start at all changed plug not problem. any suggestions would be greatly appreciated.
Old Oct 29, 2000 | 08:59 PM
bayou220atv's Avatar
sounds to me like it's not getting enough gas, but I'm not a mechanic. That's what quads tend to do if you leave the gas tap left to off .
Old Oct 30, 2000 | 07:22 PM
Mojaveracer's Avatar
Check your valves. The intakes like to cup into the head on Mojave's. My old '87 mojave did the same thing until I replaced the intake valves. A temporary fix is to adjust the valves every 2-3 hours of riding until you get new ones. It could also be a carbeuration problem which i would check by cleaning it first. One more problem is that the cam chains on mojave's stretch easily. I had to replace my 00's just recently and just after I sold my '87 the guy I sold it to said the cam chain was stretched so bad that the cams skipped a few teath causing it not to run. The last thing I can think of is your spark plug is bad/fouled or something went on the ignition.
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
