a problem with my KFX 700
i was wondering if any body else is having the problem of their front tires vibrating when you go down the road at about 35-40 MPH. it only does this on pavement and really hard gravel. it is also wearing the front tires pretty fast. any help with this would be greatly appreciated, and also if i need new parts can someone tell me where to get them.
You would need a tape measure/string and a white choke to check the toe-in, and adjust the nuts on the tierods to either shorten or lenthen the tierod's effective length. It should be between zero or -5 mm, but never a positve value.
But I really think your front end vibration is coming from the out of balance front wheels. Have tire shop balance 2 front wheels and see if that reduces the vibration. BTW, why would you be riding on pavements?
