03 kawasaki prairie 360 problem
Hey Yammi---you will need a special puller---I am running short on time right now, but if you can find NYROC,s website, there is a guy on classifieds that makes and sells them for $25.00---I have one and it works fine--let me know if you cant find it and I will get back to you hopefully later today
GOOD LUCK
GOOD LUCK
hey oleman, i have come to the conclusion i have the same prob you did were the atv will stay engaged and such and will die somtimes. Im pretty sure i will need a clutch rebuild. Can you give me info on this as in what will i need and how hard. Do you suggest i go to the dealer or is it easy to buy the parts and rebuild it. I do have a manual. THanks
dont waste your time on rebuilding the clutch. go ahead and go to mfgsupply.com and get a comet clutch. for around $300 you get a brand new high performance clutch with cams and spring including shipping.. it is a good clutch with good torque..you may have to grind some on the inside of your 360 where the clutch slides on, but takes about 2 minutes with a grinder. go here http://www.mfgsupply.com/ATVCometClu...on_id=if3GbYhX
