actuator
Old Jan 30, 2006 | 09:46 PM
mudlover5's Avatar
Default actuator
hey , i jus want to clarify a few things about the actuator on my kawi. prairie 360 4x4. This part does have to do with the 4x4 right. And do you think if i brought just the actator to my dealer they could tell me if it is broke or not.? thanxz
Old Jan 31, 2006 | 04:06 PM
mudlover5's Avatar
Default actuator
can any1 help me out?
Old Jan 31, 2006 | 05:13 PM
Hayashi's Avatar
Default actuator
Why take it to a dealer? If you can take it off from the bike, you are probably capable to tell whether the actuator is good or bad. Apply 12VDC to red and blk wires and see if turns. If not, take 3 outer screws out and see if anything is jammed in the gear housing. Don't try to look inside the dc motor. It's little more complicated due to the potentiometer. If all good, apply good amount of grease on gears and put it back. If you are not getting 4WD, the next step is to check out the control unit and front diff gear box.
Old Feb 1, 2006 | 12:26 AM
bfb750BF's Avatar
Default actuator
You may want to take out all of your Fuses too, clean them up, clean the fuse box holder, apply the di-electric grease (spark plug wire grease) to help keep moisure/dust from entering the fuses. This was my Problem on both of my P650s, not the Actuators. Once I took care of the Fuses, I never had another problem with the Actuators.(both of them)
Old Feb 2, 2006 | 07:16 PM
mudlover5's Avatar
Default actuator
I took it off and brought it to the dealer for them to test it and they said its pretty much shot. Anyone know where I can get it cheaper than $250.
Old Feb 2, 2006 | 07:21 PM
Uinthas's Avatar
Default actuator
Try Ronayers.com I thik it was around $200 there, I could be wrong, I should know I have bought 3 of them [img]i/expressions/face-icon-small-disgusted.gif[/img] There's ways you can fix those, just depends on what is wrong, but you'd have to be somewhat electronics inclined...
Old Feb 3, 2006 | 05:47 PM
bfb750BF's Avatar
Default actuator
I bought a brand new one from Ronayers b/c I was told the old one was shot, which it was not. I paid around $215 Bucks for it.
Njrider1230
Jul 29, 2023 05:16 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Donniereble
Aug 21, 2015 10:46 AM
bigwave
Jun 30, 2015 11:19 AM
alisonsandmindysdad
Jul 19, 2004 11:16 AM
