05 BF 750 belt change.
well, you can either buy primary clutch puller for like 35$ or just do it like 90% of us and take a 27mm socket and slowly rotate the secondary clutch (back clutch) backwards and pull the belt off. It may take a bit to figure it out but once you roll it on then off its fine. Putting it back on is the just the opposite. for more info go to nyrocs site and go to the tech tips section. ITs the same thing as the prairie 650 so just look under there for help.
atv.dnsalias.com
atv.dnsalias.com
Jeff Roper
Feb 1, 2022 11:48 AM
