My quad pulls left when I wheelie
Yes, first off, you said your tires have the same air pressure. Do you have aftermarket tires or wheels on your quad? If so make sure all installation proceedures where done corectly. One thing that may be wrong is that if you ever adjusted your chain, you would have had to move the rear drive back. Even if you never have, it could have shifted a little. Make sure the back is all even on bothe sides, use a tape measure to measure from the front tire to the back tire on both sides. If uneven, make the proper adjusments. If all else fails, put more air in the left tire than the right. Thank you, good luck
Thanks for all the help. Tomorrow I will do what xtreme said to do. That makes sense. All of the posts do. [img]i/expressions/face-icon-small-tongue.gif[/img] I'll update and tell you. It might also be that I lean over... I tend to do that.
#15
