Brute 750, Hot on leg. Engine ice ?????
Old Jun 27, 2006 | 10:24 PM
Doctorturbo's Avatar
GOT BOOST!
Default Brute 750, Hot on leg. Engine ice ?????
Your talking about two different things.
Any coolant that drops engine temp does it by transfering the heat better in the radiator. The coolant "hugs" the metal in the radiator better. When this happens the heat will transfer faster and better in the radiator. 5 degrees or so won't do much for the heat you feel.
Just like Curls said, coat the exhaust.
Also make sure your jeting is on the money. My 700V is not bad at all.
Old Jun 30, 2006 | 02:04 AM
chevytrkn1's Avatar
thanks
Old Jun 30, 2006 | 07:25 AM
minimus's Avatar
The best thing I found was to wrap the pipe with header wrap along that side next to leg. Stainless aftermarket pipes are best for this. With the stocker you may take a chance of rusting.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
velcro7279
Aug 24, 2015 01:15 PM
Rollin23
Aug 13, 2015 01:12 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
