kfx starting problem. Help!!!
Well it sounds as if the engine is cranking over since you said you are getting spark and have good compression but it has something to do with the fuel and if the carb is fine then try blowing air through the fuel lines maybe the gas isn't even getting to the carb because you might have sucked dirt from the bottom of the tank. My dads diesel tractor had us puzzled one time and he blew through the line and dirt came out since it was clogged and ran like a charm. Do you have the right jets and needle for the setup?
#17
