carb jetting questions
Old Aug 2, 2006 | 07:44 PM
nomorenicknamesleft's Avatar
Default carb jetting questions
can anyone explain the whole rejetting carb thing to me wu
Old Aug 2, 2006 | 11:45 PM
holeshotz8436's Avatar
to rejet your carb is to just put diffirent(most of the time larger) jetts in your carb so you can ajust the fuel and air flow because when you add a pipe you move out more air faster so you need to change the jetting to make up for that air flow......i know that sounds confusing maby some one else can explain it better.....
Old Aug 2, 2006 | 11:48 PM
what size of jet and isnt there two jets...??????one for half throttle another for the rest...do i need to replace both....and if so wut sizes...im gettin a supertrapp ids2 race seriies
Old Aug 3, 2006 | 04:36 PM
hondabuster's Avatar
Some carbs have up to 4 jets (starter, pilot needle, and main). Throttle position determines which one is currently being used.
There are articles online that desribe jetting and carb theory...heres two good ones.
jetting
carb 101
Old Aug 3, 2006 | 10:29 PM
Rinman's Avatar
What are you jetting and why do you feel you need to jet anyway? Have you added a pipe? We need a little more info to try and help.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
