have to rejet with dynatex
It does work fine with the 650's. Just for info here is the letter I got back from Dynateck about the cdi on the 750 BF.
Rick.
Yes, the problem is with your Brute Force's jetting, which has been confirmed by sources around the country.
The stock jetting, while fine with the stock ignition, is insufficient with our timing curve, advance set up and increase in spark output and energy. Typical repair usually consists of new pilot jets and needle and/or needle shimming. The main jet remains stock. Once done, I am sure you will be quite satisfied.
I would suggest calling Dynojet for their jet kit and recommendations for your application. They can be reached at 1-800-992-4993.
Sincerely,
Larry Nelson
Technical Support
Dynatek
Rick.
Sincerely,
Larry Nelson
Technical Support
Dynatek
http://www.velocitydevices.com/
heres the site for the copperhead cdi, you will notice a big difference in price but no need to rejet, and it is also programmable and if you ever switch quads you can use this cdi just buy another set of hookups
Bm400ex
Jun 22, 2015 09:16 AM
RidE
Sep 1, 1999 09:14 PM
