kfx400 recall, How do i tell if its been fixed?
Old Aug 31, 2006 | 03:03 PM
Magnetosway's Avatar
Default kfx400 recall, How do i tell if its been fixed?
rpxr400, Thanks for putting up those pics.... I have a diff thread that I put up. I took my KFX400 in 2 weeks ago for the recall. Ever sinse I have had it back it seems to be heating up way too fast... 15mins idling and the muffler is too hot to touch. There's no way that they could have changed the cover plate without cleaning it out right?? One more stupid question... those pics are of the cover plate??? I don't know nuffin bout this stuff....lol
Thanks,
Michael
Old Aug 31, 2006 | 03:45 PM
rpxr400's Avatar
Michael,
Those pics are of the actual clutch cover under the water inlet form the radiator, which is replaced (the clutch cover) under the recall. The original one was magnesium, which reacts with the antifreeze, causing scale buildup as well as corrision. The new part is aluminum.
The only things I can think of is they lost all the anti-freeze from the radiator and didn't refill it after the cover was replaced. However, I also understand that you shouldn't have to add anti-freeze to the radiator, because it's supposed to pull from the reservoir. Maybe it's not doing that?
The other possibility is maybe the water pump isn't working correctly (behind the clutch cover that was just replaced?) If the water pump impeller isn't rotating and moving the water, that will definitely cause it to overheat (and worse).
I could be binding up or something.
Old Aug 31, 2006 | 04:24 PM
Thanks for the response... I'm gonna go home and check the radiator level... the resevoir is full. I did take the radiator cap off as soon as I noticed it was gettin hot and it wasn't full to the top. Only a pinky length low....lol
If I go home and the level is low then it must be the puump right? All I know is the fan is working... I don't know what to look for to see if the pump is workin.
Thanks Again,
Michael
Old Sep 1, 2006 | 09:48 AM
Please tell me I'm just goin crazy.... I went home yesterday and checked the antifreeze level. It was full to the top of the radiator... I started it up and in less then 5 mins the exhaust pipe was red hot. Is that normal???
Thanks,
Michael
Old Sep 1, 2006 | 01:24 PM
  #15
Zark's Avatar
My brand new KFX 400 does exactly the same thing. Sometimes I just warm it up in the garage and the header is steaming hot after less than a minute. I guess it's quite normal being a larger engine than my 250cc Suzuki Ozark.
Old Sep 2, 2006 | 12:29 AM
  #16
RealAceRider's Avatar
i just got 06 kfx almost 3 weeks ago and i havent got a recall yet?
do u think it was fixed b4 i bought it
Old Sep 2, 2006 | 01:17 AM
  #17
Zark's Avatar
i brought up the issue with the dealer about the recall. he told me that if there was one, all of the kfx 400's in the dealership would have had them replaced. i really hope so. i don't want it back in the shop so early. i took mine out the first time today. it was fast and getting alot to get use to. but i had a great time. i couldn't stop riding it. but 1 hour and 15 minutes was the only time i had today.
Old Sep 3, 2006 | 01:09 AM
  #18
sssduane's Avatar
No, that is not normal for the exhaust pipe to be red hot idling, that is a lean condition. Extremely lean, is the bike stock?
Old Sep 5, 2006 | 11:25 AM
  #19
What does lean condition mean? And yes, my bike is stock. I'm gonna see if I can get a temp gage somewhere...
Michael
Old Sep 5, 2006 | 11:38 AM
  #20
scootergptx's Avatar
Supersock
Hired Gun!
You should have it in about a month, so expect it soon.
They appartently got the vin# wrong on mine. First recall I got was for a 400 Mule. [img]i/expressions/face-icon-small-confused.gif[/img] Only took about 2 weeks after they sent the right number in, but I think they may have expedited that.
ultangler
Nov 30, 2024 01:35 AM
95wolv
Sep 27, 2024 12:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Matt123
Sep 29, 2015 01:29 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
