Amsoil Diff. Oil
Old Sep 14, 2006 | 04:12 PM
Formula1's Avatar
Default Amsoil Diff. Oil
Just wondering if you all who are using Amsoil in your diff. are using the same stuff in the front and rear. It says in manual the rear has to have some special kind of oil since it has a wet brake. Says to just use regular 10-W40 in front though. Found a distributor close by and I was wanting to change all my fluids out but I wasnt't sure about the rear. Thanks
Old Sep 14, 2006 | 04:32 PM
Hayashi's Avatar
Yes, the rear gear box requires wet brake oil, just like those John Deer farm tractors use.
Old Sep 14, 2006 | 07:00 PM
montyh's Avatar
Amsoil does make an oil that is within the specs. i believe it is a tractor hydraulic oil. in a tractor, the rear end/ transmission/ hydraulic oil is all the same, and since the tractors all have internal wet brakes that is the stuff. there should be some guys with the right part number chime in...
monty
Old Sep 14, 2006 | 11:37 PM
v2rider's Avatar
I use the same in the front and rear, but thats what my manual calls for (80-90)
Old Nov 11, 2006 | 11:53 PM
saby73's Avatar
1 front diff 10w40 engine oil
2 rear diff go to a kawa dealer and ask for TDH oil
3 don't use EVER EVER 80w90 in neither diffs
Old Nov 12, 2006 | 09:19 AM
Gus13's Avatar
I just changed all my oils engine-5W-30 Mobil1, rear diff- dealer wet brake oil, front diff- Amsoil 10W-40, but next time this is what I will be using.
Engine and front diff -
Amsoil SAE 10W-40 Synthetic Motorcycle Oil (MCF)
Rear diff-
Amsoil Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30 (ATH)
Old Nov 12, 2006 | 01:43 PM
kfxandahemi's Avatar
I use the amsoil hydraulic fluid in the rear of my V. It works great.
Sep 15, 2015 02:42 AM
Biggieshortie89
May 26, 2015 08:01 AM
cowboy
Mar 24, 2001 07:12 PM
H300F
Mar 13, 2001 07:50 PM
jkeirste
Dec 27, 2000 11:42 PM
