Bayou 300 Carburetor Adjustment Help
Old 09-21-2006, 03:18 PM
nekrofilliak's Avatar
Default Bayou 300 Carburetor Adjustment Help
Hi , i just clean my bayou 300 carburetor, after the clean-up i'm unable to get the correct pilot air screw and idle throttle setting, the motor fire up and stay at idle , but when i am accelerating , it backfire and stop, please can someone help me , thank you very much.
Old 09-21-2006, 07:02 PM
NorminNB's Avatar
The pilot screw setting is 2 1/8 turns out. The float height is 17.0mm. (warning about the vacuum piston) Slip the needle through the hole in the center of the vacuum piston and put the spring seat on the top of the needle. Turn the seat so that it does not BLOCK the HOLE at the bottom of the vacuum piston. Hope this is of some help to you. NorminN.b.
The following users liked this post:
MichalKLF300 (01-07-2021)
Old 09-22-2006, 11:22 AM
what i understand , is that i must check so that nedle must move freely between the sprint seat ?
Old 09-22-2006, 11:24 AM
right now if i adjust the pilot screw at 2 1/8, i am unable ti get a good idle speed and when i accelerating it die
Old 09-22-2006, 07:01 PM
NorminNB's Avatar
Is the choke sticking closed? Have you checked the gas filters in the tank. You have to remove the shut off valve from the tank , to do this.? [img]i/expressions/face-icon-small-confused.gif[/img]
Old 02-22-2019, 11:18 AM
Default 2 1/8 out...as in, tighten till it stops then 2 1/8? I am having the same issue.
Old 02-22-2019, 02:52 PM
Kymco 450i's Avatar
You need to be sure the carb is clean before seating that adjustment screw. If there were a small piece of crud in front of that needle it will become buried in there with possible damage to the needle and seat. Always a thorough clean and rebuild before starting a carb setup. Many good carbs have been damaged by forcing debris into those tiny passages.
bvolks
09-13-2015 12:57 PM
Nosniborpapa
09-12-2015 05:54 PM
Hw00d
09-10-2015 08:53 AM
rcappie4
09-09-2015 07:04 PM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: Bayou 300 Carburetor Adjustment Help
