BRUTE FORCE 650 750 CDI REV BOX
Old Oct 14, 2006 | 01:10 PM
MADREINDEER's Avatar
Default BRUTE FORCE 650 750 CDI REV BOX
HEY Y'ALL THANX FOR ALL THE INFO -- LOOSK LIKE THE VDI IS THE WAY TO GO -- APPEARS TO BE THE MOST BANG FOR THE BUCK -- AS OPPOSED TO PIPES & CLUTCHES ECT ... APPRECIATE IT --- BY THE WAY -- MY BF 650i - WAS AT THE DUNES - SMOKED A VERY TOUGH TRX450 OFF THE LINE -- (I WAS IN 4X4) - SHOULD SEEN HIS FACE --HAHAHAAH
Old Oct 14, 2006 | 07:11 PM
GEARSLAYER's Avatar
Happens all the time!
Old Oct 17, 2006 | 02:19 AM
NICE TO HEAR OTHER BELIEVERS ARE OUT THERE -- THE VDI WEB PAGE IS VERY INFORMATIVE AND IT LOOKS LIKE THE ADAPTABILITY AND PROGRAM-ABILITY IS THE WAY TO GO ---- ARE ANY OF YOU WITH THE VDI - PIPED AND JETTED OR STOCK???? - THANX
Old Oct 17, 2006 | 08:57 PM
grizzkiller's Avatar
i have a Dynatek cdi on my brute 750 and it runs great. no miss or hicup. i got the dyna because the vdi is really too expensive if your not gonna take advantage of the programmability. my stock cdi was toast so i was not gonna pay $400 for a VDI or $400 for a stock replacement. the Dyna was the best option for me at $190. besides the brute is pretty much uncontrollable as it is!!
Old Oct 18, 2006 | 09:41 AM
  #15
farginicehole's Avatar
Interesting. . . .
Old Oct 18, 2006 | 12:39 PM
  #16
FASTFATBOY's Avatar
Same with 2 other 750s my buddies have. No miss no hicup no problems.
Old Oct 18, 2006 | 02:40 PM
  #17
Kinda makes you wonder how often these internet forums and message boards are used by one company to promote their own product and sway potential customers away from their competitor's product.
Alltoys and others, please don't take offense to that, as I am not trying to insinuate anything towards you here! It does seem that almost everyone is very happy with their VDI Copperheads, and there are a LOT of people that claim to have had problems with the Dyna on their Brutes.
Old Oct 18, 2006 | 03:41 PM
  #18
alltoys's Avatar
farginnicehole,
Not a problem I still use Dyna cdi's and VDI. Some people who use Dyna on their BFs have problems and some don't pretty much a flip of the coin. Earlier BFs had problems from factory with carb needles since then it has been rectified.
Although crank trigger on the BFs are slightly different than the Prairies, ( VFs ), not all machines are tuned the same from factory. If you have a BF that will run on a Dyna then use it if it doesn't then VDI is another option.
Old Oct 18, 2006 | 04:08 PM
  #19
Glad I didn't step on your feet, Alltoys! My 750 is one of the '05 models that needed the carb needle update per the service bulletin. I've been sitting on a Dynojet kit for longer than I care to admit. . . guess I'm too lazy to MAKE time to try and install it! Mine runs pretty good, but I think some tweaking would still improve it and maybe eliminate some of the backfiring I get when I let off the throttle. Maybe I should give a Dyna a try on mine, as I think I could probably return it if it didn't work (although I always am leery about sellers' claims that they will take an electrical component back and give a refund!). Too many other expenses right now for me to justify around $400 or whatever for a Copperhead!
Old Oct 18, 2006 | 04:44 PM
  #20
alltoys's Avatar
Fargin,
Personally get rid of that Dynojet Kit sell it someone it is not worth the hasle or better yet the money. Many motor builders will tell you this. Backfireing on decel is lean I believe you may have to check your plugs to make sure. Try putting a washer under your needles see if that works. Getting the carbs on the BF is a pain but worth it in the long run.
