KFX 700 Carb problem
Old Oct 22, 2006 | 09:03 AM
lowell's Avatar
Default KFX 700 Carb problem
Hayashi, am I right in thinking that changing the needle jet is the same as shimming the needle jet,which i would much rather go with changing the needle, sounds to me like the correct wayto fix the problem.I am asking because I have the same problem as shortyno11 and its driving me crazy. Going out to check for leaks first .Thanx kevin
Old Oct 23, 2006 | 12:07 PM
Hayashi's Avatar
Yes, (1) shimming (raising a needle) and (2) changing to thinner (richer) needle jet are bascially the same, in a sense that you are increasing the size of the passage for the fuel flow. However, in my experience on my 750, the changing the needle jet gave me smoother throttle response due to its smoother shape of the tapering. I had orginally shimmed the front carb but it was little rough at the bottom end when I gave gas even though the coughing/intake popping was fixed. After changing to a richer needle jet, it was whole a lot smoother transition from the low end to the midrange power curve.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
