primary clutch help
Old Dec 4, 2006 | 08:52 PM
brutster's Avatar
Default primary clutch help
i just bought the tool to take my front clutch off of my 750 brute force.the tool i ordered was right handed threads isnt the threades left handed thread.the tool number by epi is pcp10.will this work or am i wrong help
Old Dec 5, 2006 | 12:37 PM
Hayashi's Avatar
The tool should be LEFT HAND threaded.
Old Dec 5, 2006 | 05:32 PM
kfxandahemi's Avatar
I dont know about your tool or not but it needs to be left hand threaded.
Old Dec 19, 2006 | 09:58 PM
Rowdy5050's Avatar
Sorry guys but yall are wrong the clutch puller for the BF 750 is right handed threads!! If you pull your clutch bolt out and look the left handed threads are at the very end to pull the clutch on to the shaft. Then compare it to the puller the (righthanded threads) are about half way up and they are bigger in diameter to be able to handle the force that has to be put on it to pop the clutch off. So there is to different sets of threads one set in the shaft to pull the clutch on (left handed) and the other set is actually inside the clutch (right handed) to push the clutch off the shaft.Trust me I just finished doing my clutch kit today on my 05 BF 750!
Old Dec 19, 2006 | 10:09 PM
Good, glad you replied. I always thought the KFX and the BF would be the same. Glad you chimed in before something got messed up.
Old Dec 19, 2006 | 10:34 PM
tuffEnuf's Avatar
Be sure and lube threads on your removal tool before using. Spray Dry lube Works better[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 20, 2006 | 07:17 AM
brutster's Avatar
thanx for the info you was on the money worked good. just didnt make sence to me when looking at it but you was the man on this.
Old Dec 20, 2006 | 09:11 PM
Rowdy5050's Avatar
No problem just glad I could help out a fellow BF 750 owner.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
