Brute Force 650 problems w/ 4x4
Old Dec 15, 2006 | 03:21 AM
bfb750BF's Avatar
Default Brute Force 650 problems w/ 4x4
Some take more Roll than others. 10 ft seems a bit compared to either of my 750s. Both the '05 & '07 will kick-in 4x4 within 2 feet of rolling forward @ speeds below 7mph.
Old Dec 15, 2006 | 01:22 PM
Hayashi's Avatar
SCJames,
If there is nothing flashing on the meter, you shouldn't normally worry about it.
Here is some tech info:
It is not really a function of distance that determines the 2WD and 4WD shifting. It is rather a speed reqirement, data trasmitted by the speedo sensor - the control unit's EEPROM is programmed to shift betwen 0.5 and 12.5 MPH only. This is to prevent damaging any engagement gears. That's why you don't see the LCD meter changing between 2WD and 4WD at cetertain speeds (<0.5 MPH and >12.5 MPH) regardless of distance you traveled even though you toggled the switch a while ago.
Old Aug 25, 2007 | 12:28 PM
330's Avatar
330
hey i have an 05 brute force can you describe the symptoms of your actuator problem this one acts like its not getting powerto switch but there are so many sensors iam not sure just wont go to 4x4 any help appreciated thanks
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
