4 wd and 2 wd blinking
Old Feb 4, 2007 | 12:00 AM
trailblazermudrunner's Avatar
Default 4 wd and 2 wd blinking
mi moms did this and it fried the actuatr and so probley the actuator is probley shot
Old Feb 4, 2007 | 10:41 AM
maddog56's Avatar
Originally posted by: Hayashi
2/4WD light flahsing on the meter has nothing to do with the belt light resetting procedure. The 2/4WD flashing indicates there is a problem in the either 2/4WD control or engine brake actuating system. The Belt Light flashing means there is a problem in the CVT system. They are not the same.
So, what do you do when 2/4WD is flashing?
1). Replug the Control unit under the seat to see if that will reset the light.
2). Check both actuators (4WD & EBC) for any obvious damage.
3). Count the flashing pattern (complete cycle) to determine the failure mode.
4). Take it to a dealer if you don't want to hassle with the problem.
5). If you dont have anything nice to say.... then dont say anything. **edited by atvconnection moderator**
speedbuff
13
Nov 11, 2020 10:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Aug 21, 2015 10:11 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
