Kawa Bayou 300 2wd Ground clearance
HELP! I own a 2000 Kawa Bayou 300 2wd and like playing in the mud,climbing,and basic riding.My problem is the thing just top centers to easy.I need ground clearance.I have called many companys about lift kits to no avail.Am I the only person in the world who wants to lift a 2wd atv?Everything is for 4wd and they say that there is no way it would work on a 2wd.Im already planning on going to 12 inch wheels and 25 to 26 inch tires but what else can I do?
Any ideas anyone??
Any ideas anyone??
"Mud" tires on the front won't help much, since your quad is 2WD. The Bayou has lots of clearance to start with; 25-27" tires ought to fit the rear without any problem; I wouldn't invest in anything bigger for a 2WD; the front will take bigger tires, too; extremely wide tires will require spacers.
Diogenes
Diogenes
I had a bayou 300, and put larger and wider tires on the rear (needed spacers), but couldn't ever change the front. My friend groung clearence is everything, so if you can put a larger dia tire up front that will be your best bet! Be carefull with tire selection though as after market tires are mostly four ply or six ply plus more rubber in a larger tire equals more wieght. This extra weight will rob power from your bike. My '96 300 was way down from the power I had with stock tires.
In the end the 300 was a great bike.......but got tired of being hugh centered so I traded in for a 2001 praire 300!
Good luck
Good luck
Sw00p
09-24-2015 02:50 PM
