Broken Tecate kick starter?
Old Dec 25, 2000 | 11:28 PM
atv_guy's Avatar
Anyone ever fix a kick starter that just spins without engaging the engine? My '85 Tecate trike just started doing this. Sometimes it catches, sometimes it just ratchets up and down. The arm's not slipping on the shaft, there's a ratcheting noise so it's an internal problem. Please tell me it's an easy fix, OK?
Old Dec 26, 2000 | 10:41 PM
atv_guy's Avatar
No one has had this problem? Then it must
be a rare occurance.
Old Dec 27, 2000 | 11:45 PM
scottbl99's Avatar
yes i have a tecate 4 and have had the same problem you need to replace the kicker gears inside the case, which is a kinda cheep fix....good luck
Old Dec 27, 2000 | 11:54 PM
atv_guy's Avatar
Scott, that's what I wanted to hear, thanks.
After the X-mas I just had santa is kinda
low on dough if you know what I mean. My
rear brake isn't working either. My local
Kawasaki dealer said to bring in the
offending broken bits and he will lighten
my wallet. That thing really rips though,
the power delivery is severe.
Old Dec 31, 2000 | 02:34 PM
Cartman's Avatar
atv_guy I FEEL YOUR PAIN!
I've went thru 3 of them dang buggers. The trick is, when installing them, turn the gear as far as it will go clockwise, then install your spring. It took me blowing out 2 of them before I learned the trick
ghost civic
Jan 15, 2020 07:43 AM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
mdigitale
Aug 6, 2015 12:35 AM
raceware
Jul 30, 2015 06:59 AM
JoAnnS
Jul 23, 2015 02:18 PM
