Bayou 300 Reverse Lockout Knob Deactivated
Old Aug 5, 2007 | 11:56 AM
rjestes3's Avatar
Default Bayou 300 Reverse Lockout **** Deactivated
I just bought a 1995 Kawasaki Bayou 300 2x4 with manual tranny. The Reverse Lockout **** has been deactivated.
First, Is that a good thing?
Second, would that have been done by cable adjustment, or what needs to be done to reactivate the Lockout feature?
As always, all help appreciated.....
Jim
Old Aug 7, 2007 | 10:07 AM
rjestes3's Avatar
In the event someone reads this and has a similar situation with a deactivated Reverse Lockout ****, I found the solution. It is a simple adjustment of the Reverse Lockout Cable. Near the foot shift lever, the Lockout cable has two 10mm nuts that can be adjusted. Take out the cable slack and the Lockout **** can be deactivated so you can shift into reverse without turning the ****. Allow slack and the **** does its intended job, keeping you from accidentally downshifting into Reverse..... Hope this helps!
Regards, Jim
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
rcappie4
Sep 9, 2015 07:04 PM
poutlaw525
Sep 9, 2015 03:19 AM
