P700 front end noise.....
Old Sep 5, 2007 | 09:56 PM
Executioner's Avatar
Default P700 front end noise.....
I have a front end squeaking noise from my shocks or something. This noise is driving me crazy!! It makes the most noise when I drive it over uneven ground. I can't pin point where the noise is coming from. If anyone has had the same problem can you please tell me what to do?
Should I grease something? Any help would be most appreciated!
Old Sep 6, 2007 | 11:49 AM
Hayashi's Avatar
You need to give more info - in what kind of situation(s) would the squeaking noise most likely to occurr and from where more specifically if you can pinpoint? For examaple, accelerating, decelerating, going over bumps, uphill, downhill, slow speed, high speed, left, right, middle ???
On my P700, it was the left A-Arm pivot bushing when compressing the front end. But it could be something else on your bike.
Old Sep 6, 2007 | 08:45 PM
Situation = anytime I drive it noise is always there. Not much noise on even ground just uneven.
Now that you said A-Arm it sounds like that is it, then again it's hard to put me head down there when I'm driving. [img]i/expressions/face-icon-small-smile.gif[/img] It almost sounds like the noise is coming from both sides.
Even when I push down on the front end it doesn't always make the noise.
If it is the A-Arm bushing do I replace the the bushing, or will some grease do the trick? Thanks for the help!
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
