97 400 prairie auto
Old Sep 11, 2007 | 10:45 PM
elejr1's Avatar
Default 97 400 prairie auto
When I turn the switch on the running lights will work but it will not cranck. The console lights do not come on either. I jumped the starter soliniod and it will cranck but not start. The run switch is also on and I changed the main fuse. Any thoughts to what it might be?
Old Sep 12, 2007 | 01:48 PM
Hayashi's Avatar
It sounds like you have a bad chassis ground connection some where. Look for a heavy gauge black wire with an eyelet at the end that's bolted on to the frame. Remove the eyelet, file/sandpaper the frame where it connects to remove any corrosion/rust/paint - you want to see the bare shiny metal.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Clint Russell
Sep 25, 2015 03:20 PM
Alex G.
Sep 19, 2015 06:34 PM
PrairieDog126
Sep 12, 2015 05:23 PM
