2008 Prairie speedometer install
I'm new to the world of ATVs and this forum, just picked up a 08 Prairie and got a speedometer, the guy at the dealership said, just pop off the plastic circle and plug in the 3 wires (red, blk, green) to the open connections.
Here in lies the problem, I searched everywhere for these colors and open connections with no luck.
I took off the two screws which hold the cover, lifted it up a bit and peered around for a long while.
Does anyone have any tips on this? Are the wires I'm looking for terminated or taped up somewhere else?
Thanks,
Thanks,
Well, I'll answer my own topic, in case someone else is having the same question.
The 3 wires are tucked away in a separate bag, zip tied together. So after you undo the first bag, there is a second around the 3 receptacle wires.
To get to them, I loosened the left side of the fender (as if you were sitting on it) enough to where I could separate the fender from the main body. Of course, you have to take off the front rack, but just loosening this up and pulling back on the plastic gave enough room to get your hands down in there and find it.
So, Do not look for the wire colors, they will be in another black zip tied bag.
I had read in other forums that people took the entire fender off, and others who spent hours digging for the wires.
Yeah, it was a bit of a pain, but well worth it. I only have 15 miles on the quad so far, but I absolutely love this machine. Took it antelope hunting this past weekend. We get bad spurs / stickers out here in SD, so I opted for the 6 ply mud lites, injected them with some slime (cactus juice) or whatever people call the green stuff... and it worked like a champ. I'm already eying another prairie for the wife...
Awsome man, glad you like it. Here is a tip for the prairies. Make sure you use low gear when ever pulling, pushing, or going 10 mph or less and your belt should be good. Using high wears out the belt quicker needinga new belt or belt adjustment. Enjoy man
<div class="FTQUOTE"><begin quote>Originally posted by: ryanee
I had read in other forums that people took the entire fender off, and others who spent hours digging for the wires.</end quote></div>
I'm having the same problem. I unfortunately pulled the RH side fender up (as that was where the dealer said it was) and didn't find anything. I'll try the LH side tomorrow. Thanks!
Scooter's Shop
23
Oct 22, 2015 07:04 PM
2008, 360, add, atv, install, installation, installing, kawasaki, parie, plug, praire, prairie, quad, speedo, speedometer
