no compression
Old Nov 23, 2007 | 05:56 PM
gator6767's Avatar
Default no compression
hey guys i am new here and new to the atv world i found a 89 bayou 300 for next to nothing it ran but not well i had to change a head gasket i lucked out and got it re timed but i didnt have the timing sprocket nut tight enough and it jumped time now i have no compression i cant figure out how to set the time any help would be great
Old Nov 23, 2007 | 10:19 PM
vbalz's Avatar
remove valve covers, turn engine over, see if the cam is turning,if so adjust your valves
Old Nov 23, 2007 | 10:44 PM
Doctorturbo's Avatar
GOT BOOST!
If it's an interference engine, your done. You wacked the valves. I don't know if it is or not? If it is, new valves are in your future.
Old Nov 24, 2007 | 07:24 AM
gator6767's Avatar
thaks alot guys this may sound stupid but what is an interference engine
Old Nov 24, 2007 | 01:08 PM
GOT BOOST!
An interference engine, in simple terms, is an engine that if you loose the timing on the engine (whether you break the chain, belt or whatever, loose the timing of the engine) the piston will hit the valves. There won't be enough clearance between the valves and the piston.
Makes for a BIG fire ball when this happens at high RPM!!! Even bumping the engine over will bend a valve on an interference engine with no timing. I don't know if this is the case or not with your engine. Usually not on a low compression engine like "most" quads engines have.
Let us know what you find out.
Old Nov 24, 2007 | 03:42 PM
gator6767's Avatar
thanks alot doctorturbo ill let you know
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
