750 bruteforce problem
Old Jan 15, 2008 | 09:10 AM
BonSR.'s Avatar
Default 750 bruteforce problem
I turned my brute force over sunday now all i get when i try to turn the key is a clicking noise at the back of it. The display won't even light up. I would really appreciate any ones help.
Old Jan 15, 2008 | 01:42 PM
stillV1's Avatar
By what you are describing, I would start with the battery. Also make sure it has a good connection at the terminals. If your battery proves to be good, then the brute force guys on here should be able to steer you in the right direction. I would check the things that I mentioned first, because thats what it sounds like to me. Good luck.
Old Jan 15, 2008 | 09:18 PM
mudblaster's Avatar
sounds like a dead battery to me.
Old Jan 17, 2008 | 12:17 AM
chevytrkn1's Avatar
The stock batteries suck, i went and got a good Interstate battery, Turns over much stronger now than even when bike was new
Old Jan 18, 2008 | 03:27 PM
BonSR.'s Avatar
I found out that is a bad connection with the winch, take the wires off it starts up hook them back up it will not start just have to find which wire is causing it
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
