throttle is hard to push.prairie 700
Old Feb 5, 2008 | 01:05 PM
sledgehammer650's Avatar
Default throttle is hard to push.prairie 700
Has anyone came up with something to make the throttle easier to push. Mine is just too hard I've tried to lube it and it helps but, good greff. I don't want a twist throttle. Just a little more comfort for a long day. Maybe then my girlfriend would drive it and I could go get a new kvx700 and play more. And still have the best of both worlds... LOL!!
Old Feb 5, 2008 | 04:59 PM
Hayashi's Avatar
I have a 04 camo P700 also. You may want to check the throttle cable routing for any kink or unusually sharp bend. Also, spray some cleaner/lubricant on the carb throttle return spring area as well.
Old Feb 5, 2008 | 05:08 PM
I'll try that. I did notice that it idled higher when turded sharp to the left. You think it would be possible to put a helper spring on the throttle return on the carbs. I just thought that maybe someone has been through this before and had already made some kind of mod to help. You guys kick butt when it comes to mods to make life a little easier. Thanks again for your time.
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
Jazperman
Aug 7, 2016 08:12 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ashley S
Aug 6, 2015 12:56 PM
