Kawasaki Prairie 300
Old Feb 12, 2008 | 05:27 PM
cowboy_pbo's Avatar
Default Kawasaki Prairie 300
Can someone please tell me where the oil filter is located and also what kind of oil to use.
Thanks.
Old Feb 13, 2008 | 09:37 AM
alisonsandmindysdad's Avatar
Take the plastic cover off of the left side of the engine (not the dipstick door - the cover around the door). You will find your filter there. I use Shell Rotella 5w/40 Synthetic diesel oil in mine. I'll probably get some hits as to why that's wrong...but "oh well". Since it doesn't have a wet clutch, you can get away with using about any oil. I'd probably use 10w/40 in it during the summer. Maybe 20w/50 if it gets really hot where you're at. 5w/30 if you ride in the snow.
Hope that helps.
Old Feb 14, 2008 | 03:01 PM
cowboy_pbo's Avatar
Thanks, that was a big help.
Also can you tell me how to get the cover off to get to the belt drive clutch.
Thanks.
Old Feb 15, 2008 | 12:42 AM
No problem...you have to take the right floorboard off (flaps front and rear along with the screws that hold it to the lower mounts). 10mm socket will take the bolts that hold the cover off. I think the book says to take the brake pedal off, but you can usually loosen the cable and just push the pedal down...I think it will clear. I don't know if you know the belt specs, but the minimum width is 28.8mm or 1.134". If the belt is in spec., place a straightedge across the top of the belt from pulley to pulley. Then push the belt down firmly and measure the "deflection". It should be 25-30mm max. (.984"-1.181") If it's looser than that, you'll have to take the driven clutch off and take shims out.
Hope that helps.
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
hueby
Nov 6, 2015 11:34 AM
wendal
Sep 15, 2015 01:50 PM
PrairieDog126
Sep 12, 2015 05:23 PM
