kfx 700 slip on
Old Apr 20, 2008 | 03:39 AM
RPM's Avatar
RPM
Default kfx 700 slip on
As I posted in the other thread, if all you did was put on an HMF slip on, you most likely won't need to re-jet. The KFX 700 comes a little on the fat side from the factory. And you are Carburated not Fuel Injected.
Also, in order to get a reading from your Spark Plug, you would need to do a throttle chop. That is where you run it wide open for an extended period of time, shut it off and pull the plug. There are arguments for and against whether or not this works, because the type of fuel you run can skew the results.
The best way to tell if you are jetted right is HOW DOES IT RUN? If it starts, runs, doesn't pop or load up, doesn't foul plugs, or run hot, you are pretty close to being jetted right.
In order for you to hurt it from being LEAN, you would have to be Way Lean and you would know if you were.
Old Apr 20, 2008 | 03:40 AM
wapiti1's Avatar
Thanks RPM Iam glad some one else chimed in. A little rich. No prob as long as your not fouling plugs your good. Ride and enjoy.
Old Apr 20, 2008 | 03:45 AM
kfxrenegade's Avatar
thanks...wapiti1 and RPM that helps i feel much better......
Old Apr 20, 2008 | 03:46 AM
RPM's Avatar
RPM
These KFX700's actually run better running a little on the rich side. But you would have to really Lean them out to burn one down.
Old Apr 20, 2008 | 03:49 AM
  #15
just one more ? I have an 08 can am renegade that i just got a hmf pipe in for, and it is EFI, does the same go for it or are there changes i need to make, since talkin to you guys i have hesitated putting it on cause i dont want to ruin anything, any answers
Old Apr 20, 2008 | 03:56 AM
  #16
RPM's Avatar
RPM
An EFI system gets input from several different sensors. A slip on doesn't make a drastic difference in the amount of exhaust gases being evacuated and therefore isn't going to require a new EFI mapping. I would bet that the EFI can more than adjust any fuel requirements needed if any.
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
