KFX400 problem please help asap
Old Oct 27, 2010 | 10:38 PM
Pizzle's Avatar
The choke may be getting stuck. You gotta pull the carb apart again and clean out the choke valve.
Old Dec 14, 2010 | 08:25 AM
windsor396's Avatar
More than likely is the pri/res switch (fuel shut off) change it over to reserve. For some reason these things do not like running off primary due to faulty switch. If you run it on reserve you will be fine. Mine did the same thing..
Old Jan 10, 2011 | 03:45 PM
windsor396's Avatar
I must apologize for posting the same response in the same thread. I hope you find/found your problem and have been able to fix it..
Last edited by windsor396; Jan 10, 2011 at 06:25 PM. Reason: I repeated myself in different posts.. WHAT A GOOF!!!
Old Jan 10, 2011 | 06:20 PM
atacama's Avatar
i will start for replace the spark cable and end ruber piece
Old Feb 17, 2011 | 10:16 PM
  #15
rjestes3's Avatar
In addition to checking the tank vent, you might disconnect the fuel line at the carb and check the gravity flow into a clean container. Rust or dirt at the tank valve filter, or a partially clogged in-line fuel filter can cause similar trouble....fuel is adequate at idle and low speed, but fuel doesn't feed fast enough to supply higher demand....
Jim
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Jul 29, 2015 01:24 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
