Leaking carb
Old Aug 28, 2008 | 11:38 AM
AWEILRIDE's Avatar
Default Leaking carb
I just pick up a 91 KLF 300C Bayou. Cleaned & Soaked carb body and installed a carb kit, the unit runs but leaks out of the bottom of the bowl. I have already tried replaced the o ring on the drain needle but did not work.....Is there a seat for the drain needle I am missing or did I assemble the carb wrong any help or comments would be help full..thanks Brian
Old Aug 28, 2008 | 05:19 PM
Honda777's Avatar
Check your float level adjustment, there should be a procedure for this in the rebuild kit .
Old Aug 29, 2008 | 12:45 AM
PoRider's Avatar
The float level adjustment is right. Your float is set too high and is overflowing into the drain. The bowl overflow bypasses the drain screw.
Old Sep 3, 2008 | 11:20 AM
AWEILRIDE's Avatar
Thanks for the feed back. The top of the needle were it attaches to the float it is spring loaded so I have no way to adjust the float. The carb only seems to leak now when the unit is off and not when it is running.
Old Sep 4, 2008 | 09:22 PM
PoRider's Avatar
Almost all of them are spring loaded. Rare do you find one that isn't. So it can still be adjusted with the tang on the float. You may want to change the needle and seat so it will seal better. If not, just shut your gas line off when you shut off the bike.
Old Sep 5, 2008 | 05:09 PM
AWEILRIDE's Avatar
It is a new needle with the teflon type material which I thought would replace the seat...correct me if I'm wrong. I thought the float was non-adjustable since it was spring loaded, so the float should sit parallel to the carb base when the carb is upside down just as with a small mower engine. thanks again for the help
Old Sep 6, 2008 | 02:03 AM
PoRider's Avatar
Floats don't always sit parallel to the carb base. More likely it is a measurement specified by the manufacturer. Viton needles are only part of the equasion - the seat is just as important for the seal.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
