help....with my lakota
so i take my lakota to the trials for the first time ever and i noticed then i go to shift it leaks oil out the shifter and i mean pours out when it is running it drips i let my buddy do the oil and filter change last night and he put 2 quarts in idk if that enough or not but on the window it showed to the low line then after riding for awhile its seem to be over filled so idk if its to full and thats what is causing it to leak like that or a bad seal what do u guys then... and when im giving the thing some gas in a higher gear like 5th 6th it sounds like the clutchs are slipping u have to back off the gas and let the rpm;s caught up...
<div class="FTQUOTE"><begin quote>Originally posted by: 680
sounds like too much oil dude. call your local dealer for the correct oil capacity or just buy a honda</end quote></div>
i hope to much oil...and just buy a honda..lol i love honda car's i owned a honda dirt bike some what likes it but i like suzuki and kawi...
wow -- right night to the oilfiller is a 1/2" tall lettering
1.7L
the shifter runs basically through the oil to reach from left to right side. If you lift the shifter and oil pours out, you COULD have a motor killing problem, or just in need of a $130 part.
where are you located?
1.7L
<div class="FTQUOTE"><begin quote>Originally posted by: jeffeosso
1.7L
where are you located?</end quote></div>
im located in columbus,ohio oil yeah i seen the 1.7 my buddy added 2 quarts and said it wuz on the low line and i looked and it wuz...i took it out for the day and noticed it wuz leaking i looked in the little window and it wuz full rode for the rest of the day like that it leaked out still to almost normal level...so what do u think it wuz to full? or what and the cluth seem to slip in high rpm...
1.7L
